Reshaping objects with the Freehand tool
Mode
Tool
Tool set
Shortcut
Freehand Edit
Freehand
Basic
Alt+5 (Windows)
Option+5 (Mac)
A polyline, polygon, rectangle, circle, or arc can be reshaped using the Freehand Edit mode of the Freehand tool. The direction of the curve drawn determines the new object shape. An edited object is converted to a polyline after editing is complete.
To reshape objects using the Freehand tool:
Select a valid object.
Click the tool and mode.
Click to draw the new curve, editing the valid object using the following curve direction guidelines:
Action
Guidelines
Change existing curve
Connect two points with new curve
Create closure with new curve
Add a new curve to an existing curve
Extend existing curve
Retain partial curve
Click again to finish drawing the freehand polyline edit. The valid object is edited and converted to a polyline.
Polyline tool
Reshaping objects
Closing and opening polygons and polylines
Displaying and reversing object direction
